Battery Overheating- 97 Discovery 4.0
Old Aug 19, 2015 | 05:36 PM
DiscoInferno97's Avatar
Default Battery Overheating- 97 Discovery 4.0
I've had this reoccurring problem where I would be driving for a while and I would start smelling a rotten egg smell in my vehicle. I've narrowed it down to the battery overheating but I can't figure out what would be causing the battery to overheat. If anyone could somehow point me in the right direction that would be a great help. I have a DMM, Test lights, and a system tester btw
Old Aug 19, 2015 | 06:28 PM
ihscouts's Avatar
Catalytic converters smell like rotten eggs too. What kind of fuel mileage are you getting?
Old Aug 19, 2015 | 06:39 PM
I directly smelled the battery after I had shut it off and the smell was definitely coming from the battery It's not the catalytic converters cuz I've already tested and they were about two years old anyway. Mileage is fine, It's definitely the battery
Old Aug 19, 2015 | 06:43 PM
june82000's Avatar
Are you showing any codes?
Old Aug 19, 2015 | 06:47 PM
No none related to the charging system or battery..Just a couple random misfire codes
Old Aug 19, 2015 | 06:52 PM
Not catalytic converters those are working fine My fuel mileage is good. It's definitely the battery I smelled the battery after I shut the vehicle off one day and it was definitely coming from there
Old Aug 19, 2015 | 07:46 PM
ihscouts's Avatar
With engine off battery should read 12.6VDC. With engine running battery should read 14-14.2VDC. Anything over 14.8VDC and you should have the alternator checked. If the alternator needs to be replaced (the internal voltage regulator fails) have it rebuilt professionally.
Old Aug 19, 2015 | 08:08 PM
Thanks ih I read 17.9VDC even though the tester said that all was good.
Old Aug 19, 2015 | 08:45 PM
ihscouts's Avatar
Way too high! The voltage regulator is non-existent, toast. Your about to blow up your battery or have a fire. Don't drive it until you find another or get yours rebuilt. It's that serious. If it's off-gassing where you can smell it and the voltage is that high your taking a huge chance. I'm serious. Find either a used alternator, buy a rebuild kit or get yours rebuilt. I have a heavy equipment shop nearby that rebuilds earth moving equipment electrics plus and they charged me $50 for one I had on the shelf as a spare (that was free). Do something now! Don't get a lifetime rebuilt from the big box stores, they crap the bed often and you'll be replacing them often.
Old Aug 19, 2015 | 09:44 PM
Yeah this will be number three never going back to the box store special alts, all three failed in different ways. I will not be driving it anywhere till it is fixed. I found a local shop that will be doing the rebuilding. Thanks again
