BCM changes from 1996-99?
Old Apr 17, 2021 | 09:09 PM
kmurzyn's Avatar
5th Gear
Default BCM changes from 1996-99?
Hi all,
Needing to replace BCM (Body Control Module) unit behind glove box. Cheaper ones I'm seeing are for the 1999-2004 Discos. I have a '97 Disco 1. Anyone know if the BCMs are compatible?
Old Apr 18, 2021 | 09:30 AM
jimvw57's Avatar
the D1 did not have an BCM per say, just a bunch of separate modules that controlled different things like alarm, windows, cruise, etc. the D2 used a BCM.
Old Apr 18, 2021 | 09:40 AM
robertf's Avatar
Its referred to as a multifunction unit and its not near as embedded into the vehicle as the series 2 BCM.
94-95 and 96-99 are different part numbers and color. I don't know if they are compatible, the fuse blocks are slightly different between the break so I would guess they are not.
The series 2 BCM is not at all compatible, it is a totally different vehicle electrically
Old Apr 18, 2021 | 12:19 PM
kmurzyn's Avatar
5th Gear
Thanks guys. I had gotten confused with interchanging terminology : ECU vs BCU and BCMs.
What I really needed was the single module, so that's easier.
trstefani
Dec 20, 2023 03:30 PM
DakotaTravler
Aug 27, 2020 09:20 PM
ljdiscovery
LR4
Jul 21, 2019 02:29 AM
bluetick
Jan 6, 2019 08:31 PM
ihscouts
Jun 30, 2011 12:06 AM
