Bedliner for interior?
Has anyone done a spay-on/roll-on bedliner material for an alternative to the interior carpet and plastic side walls. I don't know if I'de do the headliner as well, don't know if that would loose or retain the insulative layer that the headiner provides? It would be sweet to just hose it out. I want to add tie down points and get them covered in the bedliner too. I know I've seen some pics floating around of some similar projects. Any help would be appreciated. Thanks
I did it on my 4runner
Did the entire floor. Didn't take too long, used about 3/4 of the bigger contraner thay sell [1/2gal?] It held up great. However I removed the insulation, and cannot comment on if it will stay hard ontop of soft insulation.
I had 33" Mud tires so the road noise was a little excess.
I did my ceiling in chalkboard paint. Haven't tested out the sidewalk chalk on it yet but it sure beats a saggy headliner. There are pictures in my profile. It looks great by the way, and I haven't noticed a difference in sound. Sure does sound different with NO headliner in, sounds like a house with a tin roof when it rains.
I have contemplated bedlinering the floor but when I looked under the carpet it looked like it would be a hard undertaking trying to hide or re-route all the wires.
wonder where you got that idea? lol..
before you put the headliner in you should have brushed the whole thing with cheap white chalk and then brushed it all off. then it would be ready for use. i use indoor chalk for children cuz its nice and chunky.
Thanks for the info guys. Spencer, how did you re-route your wires. I had a thought about running some narrow tube/hose w/ a slit down the side from up front along the floor and just cover it along w/ the everything else and open the slit abck up to run the wires.
I have removed the headliner and carpets, padding etc. from my 97 Disco. I am retaping and rerouting the wiring bundles as I go. I do have some minor corrosion issues to address. There are also a lot of factory things that I don't care for, like the use of tape and stick on dots to conceal but not seal the multiple holes and such from the original manufacturing processes. I plan to seal all those little areas that allow water to get in.
My question is: what benefit does the bedliner really provide? A painted surface would do the same thing. If you are not careful, you will end up with moisture entrapped between the bedliner and the floor panels which accelerates any corrosion issues.
I don't plan on recarpetting. I do have some heavy duty Michelin Floor mats that work just fine.
You can get various conduit type stuff for running wires in. I really don't like the way the stock wire bundles are done in these vehicles. I have been rewrapping, rerouting, reclamping mine as I go. I did a lot of work with military aircraft and missile wiring in the years past, so I am improving mine as I go. I will most likely relocate some of the items, like all the electrical components under the driver's seat.
I already snatched out the factory CD changer. More stuff to be done as I go along.
No need to in my 4runner. There were only 2 or three exposed in my 4runner and they just ran from under the door sill to under the seats. I coverd them with wire loom and they were good.
Hurculiner is STUPID grippy
