???? best thermostat for Disco I ?????
Old Jul 8, 2012 | 04:41 PM
drdeadchef's Avatar
Default ???? best thermostat for Disco I ?????
ok ,
with all the volumes of wisdom out there , I need the best t-stat for my Disco I. It is so hot here in AL right now, Satan called and asked for his cool weather back. I am planning on rodding my radiator in the next week or so, and am going to replace all the hoses, water pump, and t-stat. ALSO how much should a rad. shop charge to rod out my radiator??? I have recieved quoted from 65$ all the way up 475$.
Phillip
96 Disco 153k
no mods yet, but you just hide and watch
Old Jul 8, 2012 | 06:31 PM
antichrist's Avatar
65$ sounds about right. $475 was probably for a recore.
You want a 180F thermostat.
Old Jul 8, 2012 | 07:40 PM
oilspotLR's Avatar
$65 is really cheap!
180F ALL DAY EVERYDAY!
Old Jul 8, 2012 | 07:45 PM
woodruff_sc's Avatar
4wd High
I just replaced mine with a 180deg from Mr Gasket fits perfect
Old Jul 8, 2012 | 08:09 PM
CUpgt's Avatar
180* for sure. Mine ran no hotter than 204 through the mountains on the way to Asheville, NC with the AC on in 97* heat. No hotter than 185 on the way back down the mountain. Its a small block chevy stat with an 1/8" weep hole drilled in the front. Available at any parts store.
Old Jul 8, 2012 | 09:22 PM
Discolife's Avatar
Whats is the stock thermostat temp?
Old Jul 8, 2012 | 09:53 PM
That's a good question. The RAVE says opening 88 degrees. Rimmer Bros (UK volume parts dealer) sells an 82 C and 88 C both as OEM. But antiChrist also makes a good point, many euro stats are marked for fully open temp, while US market stats are marked for "starts to open" temp. On most mechanical stats start to open is about 15 - 20 degrees behind fully open.
Here's a link to Rimmer's page Discovery 1 Thermostat & Temperature Sender at www.rimmerbros.co.uk
The D2 stat data is in the RAVE, starts to open at 180F, fully open 204F.
I like my 180F stat.
Old Jul 8, 2012 | 10:01 PM
Discolife's Avatar
195 is what the OEM is for the Disco I 97 model
Old Jul 9, 2012 | 05:47 AM
drdeadchef's Avatar
OK so 180 it is, I keep reading about a soft spring t stat on here what exactley is that that and does anyone hv a part number for this t stat? also something about a hole drilled in it, do I do that or does it come likew that?
Phillip
'96 Disco 153k
Old Jul 9, 2012 | 05:55 AM
4wd High
Most stats come with a air bleeder/toggle in the outer flange, when ever I change out a state I brk off the toggle and widden the hole. This make it easier to remove all the air from the sys..
