???? best thermostat for Disco I ?????
Old Jul 10, 2012 | 06:45 AM
  #21
antichrist's Avatar
Originally Posted by drdeadchef
what happens if I use a 160 t stat, in stead of a 180?
woldn't that 20 degrees be better?
I'm fairly certain Land Rover had technical reasons for specifying the thermostat they did. Why would one colder than they engineered for be better?
Old Jul 10, 2012 | 02:20 PM
  #22
Discolife's Avatar
Phillip
'96 Disco 153k
My Jag XKR has a 180Degree factory stat. or 83C which ever you prefer.
Yes cooler engines run more efficient. However to pass emissions combustions temperatures need higher temps in order to get the number they need.
The other issue is that some motor vehicle combos will see a certain amount of heat produced and there is little to NO way of reducing it unless you over engineer or speend to much money keeping it cool.
When you use a 160 stat, in a particular climate, it will always be wide open and NEVER allow the fluid to "dwell" in the radiator long enought to cool it and then you start having heat soak which will cause the system to overheat.
Our fluids have to have enough time in the heat exchangers in order for them to operate.
Example:
a 2001 Volvo XC70 turbo 5 cyl auto, had a horrible time keeping the nissin (sp?) transmission operating. The rad was small anyways way, but the tranny fluid never spent enough time in the radiator to keep it cool, fluid temps maintained a border line temp and wore those transmissions out within 100K.
The fix was to add an external tranny cooler.
The perfect way to see a car being cooled is to see water temps below stat opening temps
OR
See the coolant temp cycle........I see my coolant temp cycle on our landy with the radiator. 185-195, it fluctuates constantly in hot enviroments.
Old Jul 10, 2012 | 03:08 PM
  #23
ValveCoverGasket's Avatar
overcooling your engine is just as bad, though the damage becomes apparent more slowly, as undercooling/overheating it.
Old Jul 10, 2012 | 04:15 PM
  #24
DiscoRover007's Avatar
Because it's Land Rover. They also designed a non grease-able driveshaft that will blow your transmission out. They also made the heater core virtually inaccessible with out removing/cutting the dash. They most likely made the t-stat the way they did to deliver heat faster for driver comfort.
As easy as they are to work on they can be just as inconvenient to fix. Company's make stupid design decisions all the time.
Old Jul 10, 2012 | 10:40 PM
  #25
antichrist's Avatar
A 180 isn't going to deliver heat substantially faster than a 160 since they both start out closed.
Old Oct 15, 2017 | 04:26 AM
  #26
stephnsons's Avatar
Default Best thermostat
Very informative thread.
Old Jan 17, 2018 | 02:27 AM
  #27
zigzag3141's Avatar
Thermostat I’d say depends on where u live and if you want your Heat to work. I run a 160deg in my 96 in Texas.
Old Jan 18, 2018 | 10:24 AM
  #28
Toran's Avatar
I installed this a couple months ago and all has been working fine.
Got it from Amazon for under $8.00. Make sure you order a gasket too!
Stant 45858 SuperStat Thermostat - 180 Degrees Fahrenheit Stant 45858 SuperStat Thermostat - 180 Degrees Fahrenheit
gribur
Apr 10, 2014 08:29 PM
bcolins
Aug 13, 2013 04:22 PM
Chris in Maui
Mar 26, 2009 09:10 AM
Chris in Maui
Mar 25, 2009 12:29 AM
