body corrosion
Old Nov 17, 2013 | 10:25 AM
mpcrnc's Avatar
Default body corrosion
Does anyone know a good body shop that can do corrosion problems in the body? I am in Northern Virginia. Mike
Old Nov 17, 2013 | 12:57 PM
m1943's Avatar
Hey.
Where is the body rust, it's an old truck, perhaps you could some repairs yourself? I use a steel brush tip on an electric drill, then sand paper, then rust solvent (acid, turns it into primer-like substance, then a little putty, and you can get aerosol can primer and paint by Rustoleum or such. One sunny day in you driveway and you're done, unless your rust damage is major. Other than that, there is a couple of places that are affordable in Falls Church and in Arlington. You can PM me if those locations are good for you. Two of them are on the same street.
Old Nov 17, 2013 | 02:09 PM
mpcrnc's Avatar
the rust is in the fender wells and door openings and the rocker panel. I installed safari guard rock sliders and there is corrosion behind them. My son had the car in Vermont for the last 3 years and I just got it back and am just going through it. My list is growing rapidly. Let me know the places that you are referring to. I live in Arlington. Fall Church auto body actually put a new roof on it when a tree landed on it about 12 years ago. Mike
Old Nov 17, 2013 | 04:41 PM
m1943's Avatar
I pm-d you.
Old Nov 17, 2013 | 05:54 PM
mpcrnc's Avatar
Default corrosion
Thank you for the information. I will try one of the shops after I finish surveying the damage. Mike
99LRDisc
Oct 14, 2008 01:31 AM
jofnui
Mar 7, 2008 06:45 PM
N.Franklin
Nov 2, 2007 01:13 AM
chris
Appearance & Camping Set Ups
Aug 2, 2007 04:21 PM
howellja
Apr 29, 2007 10:52 PM
