brake line rupture
Skip the stainless and get copper-nickel. For the price of one prebent line you can buy enough c/n line to do the whole truck, a flare tool and a cheapie tubing bender. Really, the stuff is so easy to work with you almost don't need the bender but I would use one anyway. Flare tool you can get at sears, most every parts hut in existence will have the c/n tubing in 25' spools, and precut shorter lengths as well. If I remember correctly I bought 75', way more than I needed for the whole truck, the flare tool, the tubing cutter and bender for less than $120, which is what rovers north wanted for ONE 4' long prebent crappy pot metal tube. Add to that the new skill you will learn doing it and it is a win win all around.
Ian was talking about the flexible lines. I'm assuming your hard lines ruptured, right?
Unless you really like cutting and flaring stuff, I wouldn't bother with it. You can get a 12" length of 3/16" bubble flare metric fitting brake line for about $5 at just about any auto parts store. The 12" length should just fit, get 18" if you want a little more wriggle room. Get some line bending pliers and bend it to fit. This is how I've done all my hard lines. In fact I just picked up a 51" length today for my drivers side rear hardline.
I have a (cheap)flaring tool and have successfully made bubble flares. It does an OK job. I keep it in my spares box for trailside repairs mainly. In my experience you need to spring for a good(expensive) flaring tool if you plan on doing anything more than one flare. Personally I'd rather just spend $5-8 on a length of line with the flares already made and new fittings on it and bend it to fit.
I also cut off and keep old fittings and throw a few in my spares box. I also have two lengths of 60" line with fittings stashed down where the windshield meets the dash. They fit perfectly and are out of sight and kept straight.
