Brake pads and rotor recommendation?
Old Aug 13, 2015 | 10:56 AM
Fenix's Avatar
Default Brake pads and rotor recommendation?
I'm going to do a brake job and was wondering if there's a specific brand to look for when buying parts. EBC is supposed to be good but I've read mixed reviews and some say they don't last long and they're $$$. I used duralast premium on my car and they worked better than OEM but aren't available for the Land Rover. Only the standard brakes are available.
Also are there any seals I'll need? Atlantic British sells a kit with seals so maybe I should get that.
Old Aug 13, 2015 | 01:57 PM
antichrist's Avatar
I've had good experience with Wagner pads and rotors, so that's what I use.
Assuming your hub bearings are in good shape you'll only need the hub seal (RTC3511 is the better seal) and paper gasket for the drive member. If it turns out you need any hub bearings you can get those locally, Timken SET37, SKF BR37 or *** KIT38
Maybe hub bearing nut lock washers. They can usually be flattened out and reused once or twice, but it's good to have 4 of them on hand. I'd get a couple hub nuts also, in case the previous owner used a chisel on them, which is pretty common.
Old Aug 14, 2015 | 04:54 PM
Fenix's Avatar
Do you think it's worth it to upgrade to Defender 90 brakes?
Old Aug 15, 2015 | 06:27 AM
antichrist's Avatar
Yes, I did it on mine. Also Stainless flexible brake lines.
A while back Carid.com had good prices on Cardone rebuilt calipers, even eating the core charge (which you have to since you can't send in Disco cores) the price was good. So you might want to check there then shop around and compare.
Old Aug 19, 2015 | 07:54 PM
Fenix's Avatar
Cool, I ordered everything to upgrade from Rovahfarm. I also ordered the swivel ball rebuild kit. Thanks for the help!
Old Aug 20, 2015 | 12:15 PM
WaltNYC's Avatar
Any particular part number? I need to order a set. I am still having the intermittent squealing problem at highway speed.
Old Aug 20, 2015 | 12:30 PM
antichrist's Avatar
Don't recall off-hand, but they only make one set for D1.
Old Aug 20, 2015 | 01:50 PM
OverRover's Avatar
Wagner ThermoQuite: FRONT Organic PD520 >>> OR Semi-Metallic MX520
REAR Semi-Metallic MX518
Go nuts!
Old Aug 20, 2015 | 06:24 PM
antichrist's Avatar
Looks like I was wrong, they make ceramic and and two semi-metalic. I think I've been using the thermoquiet. But it may be the quickstop.
Sorry.
Old Aug 21, 2015 | 09:20 AM
MM3846's Avatar
I'm running Centric rotors and centric (mid-grade... the next step was stoptech) with my D90 upgrade. Great so far.
