Brushguard Conversion to A-Frame
Old Apr 6, 2016 | 09:22 PM
Beachdisco's Avatar
3rd Gear
Default Brushguard Conversion to A-Frame
I would like to convert my '98 Disco's full brush guard to an A-Frame. I prefer the A-frame look and don't need the extra protection - just need a mount for lights. I was thinking of using a cut-off disc to remove the extra 'wings' around the headlamps, grind the areas smooth, then fill with bond backed by welded or epoxy'd metal inside the tubes. So, has anyone attempted this conversion before or have any thoughts to share? Thank you.
Old Apr 6, 2016 | 09:24 PM
Shiftonthefly1's Avatar
You can usually find those used for 1-200. Might be better to sell yours and find the A frame type. Or trade someone.
Old Apr 7, 2016 | 08:34 PM
Beachdisco's Avatar
3rd Gear
i like to do things the hard way but your idea sounds better. Thanks.
Old Apr 8, 2016 | 10:21 PM
Reyesahr's Avatar
I just used a bumper off an old Range Rover 200. But at local rover parts salvage ��
Old Apr 9, 2016 | 09:00 AM
TOM R's Avatar
Its coated with a powder coat type coating so unless you want to strip it it will look bad, plus its thin crappy material only good to hold lights
cogsley
Aug 13, 2014 03:24 PM
Morris0352
Dec 17, 2008 10:22 PM
JRdisco1
20
Jun 16, 2006 01:20 AM
xb70valkarye
Jun 7, 2006 06:11 PM
evillama
Mar 11, 2006 08:03 AM
