Bushings and other suspension related items
Old Jul 3, 2019 | 05:09 PM
jvarnadoe's Avatar
Default Bushings and other suspension related items
Soliciting input from the Disco 1 suspension gurus out there. I have the parts below in my shopping cart at Rimmer Brothers. I'm going to purchase the parts and slowly replace the bushings and other suspension bits a little at a time to attempt to decrease the shakes and shimmy's. Is there anything below you'd suggest that I add or subtract from this list? I omitted the shock bushings since I recently replaced the shocks with Bilstein's and they came with new bushings. They offer genuine parts (too pricey), OEM parts (listed below), and aftermarket which generally aren't much cheaper than the OEM options.
Any input is appreciated.
Bush Rear Radius Arm - STC618P1 - OEM
Part No. STC618P1$17.66
Bush Rear Upper Link - NTC1773P1 - OEM
Part No. NTC1773P1$4.75 x 2 = $9.49
Bush Radius Arm Front - NTC6860P1 - OEM
Part No. NTC6860P1$9.49 x 4 = $37.97
Bush Rear Radius Arm - NTC1772P1 - OEM
Part No. NTC1772P1$3.80 x 2 = $7.59
Track Rod End RH thread - RTC5869P1 - OEM
Part No. RTC5869P1$16.46 x 2 = $32.91
Track Rod End LH thread - RTC5870P1 - OEM
Part No. RTC5870P1$14.87 x 2 = $29.75
Bush Front Anti Roll Bar Mounting - NTC6828P1 - OEM
Part No. NTC6828P1$3.48 x 2 = $6.96
Anti Roll Bar Link Ball Joint Front & Rear - NTC1888P1 - OEM
Part No. NTC1888P1$17.41 x 4 = $69.62
Bush Rear Anti Roll Bar Mounting - NTC7394P1 - OEM
Part No. NTC7394P1$3.73 x 2 = $7.47
Old Jul 4, 2019 | 09:26 AM
fishEH's Avatar
I just went with a yellow poly busbing kit from Britpart. Been good so far.
Old Jul 4, 2019 | 02:23 PM
OverRover's Avatar
I've used the ORANGE POLYBUSH for years with great results on both DI and RRC's.
One WARNING... Don't get the RED set the ride is crazy firm!!!
> https://www.roverparts.com/Parts/9783O
> https://www.lucky8llc.com/collection...-kit-dynamic-1
For Tie Rod Ends I run LEMFORDER and L8 has a decent price on these > https://www.ebay.com/itm/LAND-ROVER-...IAAOSwgopbkjCx
++ Just a HEADS-UP your count for the Tie Rods is not correct.
You need:
(3) RTC5869 RIGHT Hand Thread
(1) RTC5870 LEFT Hand Thread
Old Jul 6, 2019 | 03:03 PM
archaeology_student's Avatar
Since you are at it, do the u-joints and get the heavy duty ones. Replaced all my bushings with OEM rubber and u-joints and the difference was immediately apparent!
Old Jul 10, 2019 | 01:14 PM
jvarnadoe's Avatar
Thanks all! Especially for the qty. discrepancy on the track rod ends. I'm sticking with the OEM bushings.
As I progress, you'll probably see additional posts from me asking for help and advice.
This forum had been an invaluable asset and I really appreciate the advice and support!
Old Jul 20, 2019 | 08:18 PM
jimvw57's Avatar
Assuming you went through the front axles already,Pivot bearings will cause all sorts of problems if they were run dry from a leaking seal at the pivot *****. been there...
Friday Night Disco
ROAMING WITH FRIENDS
Feb 20, 2019 07:12 PM
abran
Oct 28, 2018 11:53 PM
Twix
Oct 22, 2018 10:28 AM
JUKE179r
Sep 19, 2018 04:01 PM
Twix
May 28, 2018 10:52 PM
