camel cut
on
didn't work
![Name: IMAG0101.jpg
Size: 90.5 KB](https://landroverforums.com/forum/attachments/discovery-i-39/45731d1501383840-camel-cut-imag0101.jpg)
I rolled the bottom up and the lip back but I don't think it will be enough
![Name: IMAG0103.jpg
Size: 100.8 KB](https://landroverforums.com/forum/attachments/discovery-i-39/45732d1501383840-camel-cut-imag0103.jpg)
this is full flex, i could lift the bumper and pull the rear drivers wheel off the ground
![Name: IMAG0105.jpg
Size: 95.2 KB](https://landroverforums.com/forum/attachments/discovery-i-39/45733d1501383840-camel-cut-imag0105.jpg)
if I'm wheeling a good bump would take it passed this point and its not enough clearence
![Name: IMAG0104.jpg
Size: 82.4 KB](https://landroverforums.com/forum/attachments/discovery-i-39/45734d1501383840-camel-cut-imag0104.jpg)
so whats the best wat of actually trimming it, cut it leave it long and fold it over?
here's mine... using the black rubber trim (parking lot protector) as a reference point, about 3/4" below the top edge of the rubber make a cut (metal shears) about 1/4" shy of where you plan to fold the curve of the inner arch. I'd sugest saving all the trimming until the very end after you have folded the metal into a new triangular shape at the angle you need to fit your planned tires. this way you can still have a 90* inward fold from the exterior plane for strength. then trim the inner edge to folow the tapered line from top to bottom like the original.
![Name: fenderfoldandtrim1.jpg
Size: 62.3 KB](https://landroverforums.com/forum/attachments/discovery-i-39/45728d1501383826-camel-cut-fenderfoldandtrim1.jpg)
You will end up with some cracked paint at the fold point but that's a small sacrifice.
soft faced, wide pliers or a couple bits of wood in the plier jaws to protect the fender at the fold line is good.
