can't shift transfer case
Nope no lights or noise, bought from a neglectful person or changes oil once a year. Once it does engage in either lo or Hi, it bumps or thumps after you put it in either drive or reverse. Don't know if maybe the gears are worn from abuse or not would like to be able to use given the need.
These things frequently get stuck.... pull up the gaiter and foam and spray some penetrating lube on the mechanism. Look at the RAVE for a picture of how it is all attached, there are rods connecting the lever to the diff/tcase
Fixing a Land Rover Discovery Stuck Differential Lock or Transfer Case <-- google found this for me while looking of an illustration.
![](http://bahnstorm.com/rover/discofixlever.jpg)
when was the last time it worked?
Bought it from a guy who had it sitting up for a few years claimed everything worked, just wouldn't crank. Found out later that the fuel pump relay was bad now it runs. Until the other day I never tried it, guess a wild hair huh. Will start taking it apart this weekend so I won't have no distractions from work. Will let you know what I come up with.
Well fix one break two. Freed up the shifter took 15 minutes or so that picture really helped alot. Bad news it will go in gear or the slot for normal driving but it won't engage. If I put it in 4 Hi with the differential lock and slide it over in unlock and put it in gear it makes a loud gear grinding noise and won't budge. So is there a rebuild kit for the transfer case or might be better to find a working one and switch it out?
