Cant shift transfercase into High unlocked
I just bought a 96 disco and the transfer case was in High Locked but I cant shift to High unlocked, it just looses all power to the wheels and sounds like something is just spinning in the transfer case. I can go to Low locked and low unlocked. Just wont go into high unlocked. When I drive in high locked it seems to drive like it is in unlocked, I can make very sharp turns and don't hear any tires slipping or chirping or any resistance in the steering wheel and the locked light is on. Does anyone know what this may be?
Thanks
Thanks
The shifter will not go into high unlocked as in it stays there but doesn't feel like its engaged and the locked light stays on and no power goes to the wheels. Which is far right and towards rear of vehicle. It will go into high locked which is far left and towards rear and it drives normal like it should be unlocked.
Yes, nothing disconnects in the front because you have full time 4wd. The front hubs are always "engaged" unless something is broken. As Tom mentioned, do you have both drive shafts in?
If you have someone to help you, you can put your foot on the brakes, unlock the transfer case, put it in drive, and have someone peek under, hopefully from a safe distance and see which drive shaft is just spinning. (assuming it's not something in the transfer case that is broken).
