cargo storage
Old Feb 16, 2014 | 08:25 AM
  #21
TOM R's Avatar
Right now nothing holds them, I am going to put thin diamond plate on both sides and tailgate then add maybe a couple brackets on side panels for table to sit on so work in progress, diamond plate is $ so work in progress
Old Feb 16, 2014 | 09:02 AM
  #22
fishEH's Avatar
Couple thoughts, and these are just my $.02.
I would build some sort of framework or structure for the table to sit on. Maybe even have a thin piece of plywood on top for the table to sit on. I'm thinking if there is no framework then all the weight of gear on top of the table will be transferred down onto the totes underneath. The totes aren't that durable and course break on large bounces. Also, it would seem pulling a tote out with all that weight on top of it would be difficult.
Old Feb 16, 2014 | 10:10 AM
  #23
wkburns's Avatar
Also those side compartments have no strength. I would be cautious about putting brackets into them. I ended up using a drawer I bought from northern tool for a couple hundred. I will post pictures if I get to the shop this week.
Old Feb 16, 2014 | 11:38 AM
  #24
TOM R's Avatar
On drivers side there is a seat bracket On the a/c unit I will attach the diamond plate alum to and I will figure the pass side, trying to stay lightweight and no wood, got it worked out in my head just can't work on it till I recover from surgery on nerves in arm
Think the table is rated few hundred lbs. I think so just a matter of holding the ends up, like I said back of table is on the wheel wells
I do welcome ideas/suggestions
Old Feb 16, 2014 | 05:07 PM
  #25
wkburns's Avatar
You could maybe modify the brackets closest to the door off of the spot on each side where the cargo cover clips. That is right into the frame and will give you plenty of support. Below is what I did to my DII but the premises is still the same. I am not finished yet as I am putting a filler board on the top and sides of the drawer to clean it up. I will be doing the same to a 98 DI that I am building for my wife currently.
This is some additional stuff I did since I use it bird hunting a lot in the fall.
Here is the DI I am currently working on.
Old Feb 16, 2014 | 05:12 PM
  #26
TOM R's Avatar
Very nice how much was the drawer?
Old Feb 16, 2014 | 05:33 PM
  #27
wkburns's Avatar
Thanks! If I recall around 200 shipped. Your idea though of the table is good, so if you don't want to spend that much I would look at fabricating some brackets on the door posts where that clip is or was to be bolted.
Taken19
Oct 7, 2013 05:14 PM
Taken19
Sep 16, 2013 06:19 AM
Disco2Guy
Feb 13, 2008 02:19 PM
jpfemo
Oct 13, 2004 05:48 PM
jpfemo
Oct 9, 2004 03:17 PM
