Carpet pad replacement
Old Nov 21, 2010 | 10:06 PM
swampthing's Avatar
Default Carpet pad replacement
Hey folks. Need some assistance. I have a 96' DISCO used as a daily driver. Great shape, except I had leakage from a sunroof drain flood the driver's side floorboard and it went unnoticed for a while while having a head gasket replaced. The pad became saturated and mold ensued. Pad deteriorated to the point it had to be removed. Talking about just the driver's floor and tranny hump (one piece originally).
Bottom line, anyone have any suggestions on replacing the pad? Is there an aftermarket company making this stuff? Original was custom fit to the vehicle.
Please don't recommend Rhino lining. She's not that far gone yet!
On a side note, anyone selling DISCO replacement carpet in the U.S.?
Old Nov 22, 2010 | 04:19 PM
Danny Lee 97 Disco's Avatar
Any good sponge material should do as well as the original stuff if you want that water retention ability Land Rover is famous for. While you have it out, check out all the little factory holes taht are in the floor panel that are not sealed.
Also lift you rear cargo area pad and check it out for water retention.
Old Nov 22, 2010 | 06:43 PM
I would think that any carpet pad could be used and you just cut to fit.
Old Nov 23, 2010 | 01:53 PM
ColoDisco's Avatar
I recently found my padding to be soaked under the passenger side carpet. Plan on stripping it all out soon and painting the floor with POR 15 prior to reinstalling new carpet. Cannot hurt.
Old Jan 12, 2020 | 02:23 PM
DiscoNewbe's Avatar
Did anyone ever find a good source for getting replacement carpet pads?
cybercop
Apr 10, 2015 07:29 PM
errose2002
Feb 14, 2011 09:31 PM
mgabriel
Dec 8, 2008 02:33 AM
echoes_and_fractals
Aug 27, 2006 11:11 AM
