carpet removal
I did. I used the rust oleum but if you can afford it prep it and prim it yourself and then have it line x'd. It's the best there is period. The only times I regret removing carpet is when it rains cause the water from the rear tires slashes against the wheel well and it literally sounds like a waterfall other than that it's great. It can be a little noisy if you have mud terrains but not outrageous
FLA Rover (06-14-2015)
I used Monstaliner and their aluminum primer and put just the carpet back in after shampooing it. LineX is the best but it's overkill for floor boards imo and Monstaliner is a fraction of the price :-). Plus you can do custom colors. I think it definitely looks good enough to go no carpet
I use horse stall mats from Tractor Supply, heavy 3/4" rubber, cut to fit. Can hear a gnat fart it's so quiet, can't even tell if I'm moving accept for the scenery changing, well that and the roof loudly popping at 70 mph cuz it's unglued from the braces. Now when I drop my magnetic bolt retriever it just bounces, nothing but roof flashing and pop rivets - about 40% tin.
The following 2 users liked this post by ihscouts:
drivendesign (11-07-2022),
TOM R (06-17-2015)
