Changing Fuel Pump Help
Old Dec 27, 2012 | 06:13 PM
kosho's Avatar
Default Changing Fuel Pump Help
Ok im taking my fuel pump out and changing it with a new one need help. I took off all the connectors and took off the metal ring. At this point it should pull straight out but it feels like something is holding it in. Any ideas?
Old Dec 27, 2012 | 06:22 PM
You will need to wiggle it loose to break the seal that has formed after 15yrs of being smashed togetherness.
Old Dec 27, 2012 | 06:34 PM
LRchick's Avatar
After taking the black metal ring off. (if you haven't use a flat head to twist if off.)
Then I suggest you also use a flat head to lift the fuel pump, be careful not to hurt your fingers. I had a bad experience. Let me know if you need me to send pictures so you know what I'm talking about.
Old Dec 27, 2012 | 07:19 PM
kosho's Avatar
Spike555 and LRChick...Thanks guys yeah i had to use a flat head screw driver. Man that thing was stuck on there lol. Replaced the Fuel Pump. So far So good! Its running! I tried it about 5 times and each time its started. Im going to wait for an hour then try it again. Continue that for a couple of hours then I should be good to go. Thank you all for your help. It is appreciated! Thank God for the Forums and Members like you guys. Spike555 Thank you for your advice on several other posts as well!
Old Dec 27, 2012 | 07:22 PM
exploringnh's Avatar
A little late now, but it is a good idea to replace the tank to pump seal as well while you are in there.
Old Dec 27, 2012 | 08:04 PM
LRchick's Avatar
Glad I could help! :-)
Travelor
Sep 24, 2015 06:11 PM
wynhd
Dec 9, 2012 10:10 PM
JumPeR04
Apr 7, 2011 09:52 PM
discoken
Nov 4, 2008 12:39 AM
