Checking an Ignition Coil Pack
Trying to check a coil pack using an Ohm meter for resistance. I have a 99 D1 4.0L V8. I’m looking in the RAVE, but the only RAVE manual I can seem to find is for a 95/96 D1. The only resistance parameter I can find for ignition coils is for an Mpi 2.0 L… not sure if this resistance parameter is the same for coil packs on a 4.0 V8.
For the Mpi 2.0L the normal resistance range should be 0.4 to 0.61 Ohms at 20°C (69°F), does anyone know if this is the same for the 4.0L?
I’m checking the coil pack because of a P1316 code. The spark plugs are new, the spark plug wires are new… just did a head job.
Thanks!
Thanks!
DiscoNewbe (03-31-2022)
I noticed the aluminum colored HV terminals on my coils tend to get corrosion (white stuff). That is probably the main failure mode for the coils.
The low voltage side should show low ohms, and all four should be about the same. The high voltage side should show higher ohms, with all four about the same value.
Hope this helps.
Hope this helps.
Hope this helps.
Hope this helps.
DiscoNewbe (04-01-2022)
CandiMan
09-08-2008 01:28 AM
CandiMan
07-22-2008 06:53 PM
