clutch problems... this damn truck.
Old Aug 25, 2013 | 10:53 PM
Motorvated's Avatar
Default clutch problems... this damn truck.
For the first time in rwo months, my Disco has left the drive way. 15-20 miles in, the clutch pedal goes limp. I pulled it back out with my foot, it got pressure back and I was able to shift again. Seems like every couple minutes, the pedal pushes right to the floor and won't push back out. Oil level is good. Theres so many oil leaks under this tanker, its hard to tell what's wrong. Slave cylinder? Master? Clutch line?
Old Aug 26, 2013 | 01:14 PM
antichrist's Avatar
I hope you haven't put oil in the clutch MC. They use the same brake fluid as the brakes.
Assuming you actually have brake fluid in the system, have you bled it?
Old Aug 26, 2013 | 04:43 PM
Motorvated's Avatar
I used brake fluid, but haven't bled the system. Could this be a throwout bearing starting to go bad?
Old Aug 27, 2013 | 04:36 AM
antichrist's Avatar
Not likely the release bearing based on your description of no pedal. Bleed the system.
If you end up replacing any of the hydraulics, replace it all, MC-flex line-SC.
buttocks
Dec 31, 2014 12:53 AM
Spike555
Apr 13, 2010 09:21 PM
oysterhead
Aug 29, 2009 11:09 PM
Frank4
May 8, 2009 08:40 PM
