Code 1316 Issues
Code 1316 Issues
Hey guys, this is my second vehicle to have come up with an exhaust emission problem. This time it seems at little more serious though; the engine idles around 500 after its started, will stall if not revved when I stop, and the air intake makes a weird sucking sound. So far I've cleaned the air filter, the screen before the MAF and cleaned the MAF with electronic parts aerosol. For some reason the engines also has some kick back when I let off the gas. It shakes the rover. I know the fuel pump is good, it was changed about a month ago. Any ideas on what I can do would be great, thanks in advance!
on
Fromwhat I have read on previous posts on here, you should only use MAF Cleaner Spray. Try doing a search on the specific code. also do a search on maf cleaning, there are some do'd anddon't and I do not know them myself.
My 97 was really running rough and throwing 1374, 1378 codes with 115K miles on it. Changing the O2 sensors did wonders, the old ones were very sooty.
Coil pack? Sorry can't remember what year you have. Are you still getting the 1316 code?
