Coolant flows out the overflow when car turned off
#21
I've been trying to preemptively optimize my cooling system for the past two years. I was not entirely happy with temps at idle in hot weather with the A/C on.
First I installed a new fan clutch, new cap, and 180 T-stat. Very little impact.
Then I had the radiator re-cored and new coolant reservoir installed. This resulted in a 5-8 degree fall in operating temps when travelling down the road no matter if A/C was on or off. On the hottest days the truck cruises at 189.
The only remaining 'problem' is sitting at idle on hot days with the A/C on (in other words I have not been able to solve my original concern). When idling or in stop/go traffic I monitor temps with OBD monitor and adjust A/C accordingly.
Of note, when idling or in stop/go traffic, a little revving of the engine to circulate coolant and drive that fan is effective in reducing temps 5-7 degrees. I 'chicken out' at 210 and will uses throttle to cool the engine to 200-205 or simply turn off the A/C. Once under way the coolant temp drops to 190 within a couple of minutes.
Long story short, I believe you should re-core your radiator Toran. It is a $250-400 job depending on location. Well worth it IMO. I suspect your situation will be significantly improved.
Toran (07-18-2018)
#22
That's IF you can find someone to do it. We live in a time where replacement radiators for most newish vehicles run $100-200. It doesn't make sense for radiator shops to keep up to practice recoring ones when most the time its cheaper to just buy a new one.
I can get a brand new Nissen radiator for my 96 D1 for under $300. It was $365 to have my stock radiator recored 8 years ago. :/
Toran (07-18-2018)
#23
don't you guys think it's worth checking for exhaust gas in the coolant,i think i rented one for 20bucks that i got back when returned,at least he could eliminate a hg or block problem,and walt i've also been dealing with hotter than what most of you guys say your running temps are with parts that aren't that old
Toran (07-18-2018)
#25
Thank you all for the recent feedback.
I will call around town as to where I can get the radiator re-cored.
There is an O-Reileys near by I will check out to see if there is exhaust gas in the coolant.
Between now and finding a place to do a radiator re-core, I will apply Savannah Buzz's
Another Homebrew Radiator Cleaner Method
https://landroverforums.com/forum/di...-method-55045/
I will keep you all posted on whats going on with the truck.
Thank you All!
Thank you All!
#26
FishEH has a very good point. New replacement radiator can be had for <$300. Not sure if it is a two or three row unit but at least it is all metal.
https://www.rockauto.com/en/moreinfo...187120&jsn=354
And cheaper versions with plastic side tanks can be had for less.
Testing the block (pressure) or coolant (for exhaust gas) is a good idea too. Mine tested all good.
Toran (07-18-2018)
#27
#28
should be plug and play.... but you should also replace the o-rings on the oil cooler and trans cooler lines into/out of the side tanks (ESR1594). You'll need 4 (plus a couple of extra for when you foul them up)
Depending on the age of your coolant hoses, it would be a good time to replace them too.
Toran (07-19-2018)
#30
