Coolant in number 3 cylinder
Old Jan 5, 2014 | 06:50 PM
Fishman's Avatar
Question Coolant in number 3 cylinder
1994 disco with 3.9 260,000 second owner, first owner did heads & cam lifters 20,000 miles ago. Heads have arp studs all cylinders have 160 psi oil pressure is 45 cold , 45 psi hot @2500 rpm 25 psi @ idle im thinking intake gasket.there is no smoke or steam from exhaust but exhaust smell and small bubles in over flow tank sometimes it uses water somstimes it does not I pull the parkplug after it sits ten minutes sometimes there is water in number three cylinder sometimes not .When it does use water it is about a pint after twenty five miles also no overheating problem and no water in oil.
Last edited by Fishman; Jan 6, 2014 at 05:23 AM. Reason: Forgot to mention something.
Old Jan 5, 2014 | 08:19 PM
ihscouts's Avatar
The are only a few specific scenarios where you'd have coolant in #3.
Slipped liner.
Cracked head.
Cracked block.
There isn't a block coolant port at #3, 4, 5, and 6.
Pressure test the heads off the motor. Pressure test the block without the heads. Those are your only two tests available.
Old Jan 6, 2014 | 08:38 PM
Fishman's Avatar
Thanks that is what I was afraid of just was not sure how the water ports ran guess im going to pull the intake and head to see what I find and put iy back together.
Old Jan 7, 2014 | 03:47 AM
ihscouts's Avatar
I know it's not good news. Keep me posted, I'd like to know what you find.
Old Jan 7, 2014 | 06:04 PM
Fishman's Avatar
Thanks I will going to order head and valley gasket probably do it next sat.
scarrell
Nov 16, 2012 06:04 PM
Disco Alan
Mar 16, 2011 12:24 PM
hayabusarider
Mar 10, 2010 04:14 PM
tbesselman
Jun 3, 2005 02:42 PM
