Coolant Pressure Tester
Hey all, what do you use to pressure test your cooling system? I've found several on Amazon but unsure if the adapter caps will fit. Anyone have a recommendation on brand of pressure tester and adapter cap needed? Also, what pressure do we need to test the system up to; 20psi? 30psi?
TIA!
TIA!
TIA!
TIA!
