Coolant Pressure Tester
Old Dec 17, 2019 | 11:24 AM
vegas99d1's Avatar
Default Coolant Pressure Tester
Hey all, what do you use to pressure test your cooling system? I've found several on Amazon but unsure if the adapter caps will fit. Anyone have a recommendation on brand of pressure tester and adapter cap needed? Also, what pressure do we need to test the system up to; 20psi? 30psi?
TIA!
Old Dec 17, 2019 | 11:41 AM
Sixpack577's Avatar
TIA!
You should be able to rent one from an auto parts store, and the kit comes with several adapters.
Old Dec 18, 2019 | 07:56 AM
vegas99d1's Avatar
I’m looking to buy a tester, If anyone has a kit they’d recommend, I’d appreciate the brand and part number(s).
Old Dec 22, 2019 | 01:52 PM
jimvw57's Avatar
I got a Mityvac MV4560 coolant system tester from amazon. not too expensive and the adapters fit perfectly. It also would fit on my other vehicles too.
Old Dec 23, 2019 | 09:06 AM
WaltNYC's Avatar
fwiw, the stock cap is a 15 lbs pressure release.
mln01
Jul 29, 2019 03:12 PM
TOM R
Jun 22, 2016 07:02 AM
Disco_Fever
Dec 6, 2013 06:16 PM
mwindth
Jan 7, 2010 11:15 AM
david1289
May 22, 2009 10:18 AM
