crank position sensor help
Old Sep 17, 2017 | 09:17 PM
Icannap1's Avatar
Here is a picture with a different spacer from a 97 gems auto 4.0
Old Sep 18, 2017 | 05:52 PM
aemnky606's Avatar
well after a nights sleep and a new sensor in hand I crawled back under her and installed the sensor. I tuned the crank to make sure I was in the clear and realized I'm missing 2 teeth. Looks like the engine is coming back out. Or its being sold, have not decided what I'm going to do at this point.
Old Sep 18, 2017 | 07:27 PM
ihscouts's Avatar
Sure that's not the gap to time the motor? ""The reluctor ring has a set tooth pattern, 60 teeth are spaced at 6° intervals and are 3° wide, two teeth are removed to provide a reference mark at 60° BTDC for number 1 cylinder".
There should be only one "gap of two tabs" on the reluctor ring. If you have tabs missing anywhere else on the ring then it's a problem. Maybe one more night of rest is all you need eh.
Old Sep 18, 2017 | 07:42 PM
aemnky606's Avatar
There are two spots with missing tabs and the ring. My question is I could put a 4.6 crank in and still use my same flywheel right? So would a 4.6 flywheel and reluctor ring work with my truck? If so I may consider keeping her and replacing the parts. The bummer is I just had it out. I guess I'm not that smart after all.
Old Sep 18, 2017 | 09:06 PM
ihscouts's Avatar
When your done you will be "that smart". I do believe the only difference between the two motors is the crank, connecting rods, and pistons and that's it. The ring should be the exact same. Tom R reused the 4.0L's pistons to give higher compression.
Old Oct 10, 2017 | 06:04 PM
wooly123's Avatar
4th Gear
Originally Posted by aemnky606
I received my "new" engine from Paul a few weeks ago and with 100k on the clock and lots of thinking i did a complete rebuild. I will say it was very clean on the inside and had new head gaskets, at the mileage and the fact it was already out why not.
The new engien did not come with a fly wheel so i reused mine. I finnished everything up and went to fire her up and it was ugly. low RPM's knocking and spitting then she shut down and would not fire back up. After poking around i removed the Crank position sensor that came with the engien and this is what it looked like.
I did have the spacer ring installed:
What could be my issue, Ideas to correct this?
spacer should be 18 mm on automatic 1996 gems?
Old Oct 21, 2017 | 06:11 AM
aemnky606's Avatar
Ok update to this issue:
I got a new flywheel from Paul and pulled the engien out for the third time and installed all the right parts. And she is up and running for a month now!!!
Bottom line is that i have gotten real good with pulling and installing this engien and glad I did not sell her.
And yes the spacer ring was out of an manual and I have an auto so that's what messed it all up.
Old Oct 21, 2017 | 10:24 AM
ROB99DISCOSD's Avatar
Dude I gotta give you credit. It’s not many of us that stick with these troubles and don’t run away or run to a shop. Good work.
Old Oct 21, 2017 | 04:47 PM
ihscouts's Avatar
Glad to hear you kept and fixed it...... just takes patience, a few bucks, elbow grease to get things done. At the very least you are now THE resident expert on the timing ring and what spacer goes with the crank sense......
Old Oct 21, 2017 | 06:33 PM
aemnky606's Avatar
There were many days I tossed the tools down and said I'm done, but after a few days of not working on it I get lost and just happen to wonder back to it. I may be sick in the head but I find it to be therapy. I get so tied up in my job and stress just would get to me, but turning bolts just put me to ease.
Thank you all for your help.
