Crank Sensor Question
Hi Guys,
I'm currently replacing my Crank Position Sensor due to intermittent starts on my 96 Disco 1 5spd manual. I pulled out p/n ERR6357, which appears to belong to MY1999 models. From rock auto I purchased PC579 with the pigtail wiring, but that doesn't go with my setup. I was thinking I should get PC714 (looks the most like what I took out) from rock auto. Do you guys have any idea the correct CPS I should be using?
Or ERR6119 should work as well, correct?
New Crankshaft Crank Sensor For land Rover Discovery Range Rover ERR6119
Four_Stroke (02-24-2017)
