Crankshaft Position Sensor Replacement Question
Old Apr 4, 2017 | 11:31 AM
Four_Stroke's Avatar
Originally Posted by ihscouts
Mounted to his "posterior".
Oh gotcha, I'll go back to my desk job.
Old Apr 4, 2017 | 11:42 AM
ihscouts's Avatar
Glad you filled in the details. I never had to mess with the sensor on mine except to repair the wires, left the sensor installed.
I got a good laugh out of your question, can only imagine what it would look like holding the sensor in place.
Old Apr 4, 2017 | 11:53 AM
Glad someone got a kick out of it.
I've gotten pretty good at swapping these things out, little hands would make it easier for sure. But you know what they say about little hands...
Old Apr 4, 2017 | 12:00 PM
ihscouts's Avatar
Don't wanna go there, could make for a really long rant.....
Old Apr 4, 2017 | 12:20 PM
They are good for this application, don't know what you were thinking.
Hijack over.
Old Apr 5, 2017 | 03:22 PM
hrhoward's Avatar
In the interest of common decency, I will forgo that picture.
Got it replaced. Collar was loose until I tightened the bolt that holds the shield to the collar. Last couple of turns tightened everything up. Runs fine during rain storms and going through puddles. Did nothing for the occasional surging. RPM bouncing 50-60 - Land Rover Forums - Land Rover Enthusiast Forum
Old Apr 7, 2017 | 09:49 AM
hrhoward's Avatar
Here are all the tools needed to replace the crankshaft position sensor.
Attached Thumbnails Crankshaft Position Sensor Replacement Question-img_3918.jpg
Old Apr 7, 2017 | 10:46 AM
Really? All of those? The hammer and wrenches seem a bit much, but if they get the job done, so be it.
Old May 4, 2017 | 11:24 PM
rickroverover's Avatar
hrhoward.. I am chasing the same scenario. Any updates? PM me if you like.
We may need to share what we've tried.
Thanks
Old May 5, 2017 | 09:21 AM
hrhoward's Avatar
Thanks
I replaced the crank sensor and fixed the wiring. All seems good now. The little bracket dooie seemed to flop around a bit but snugged up once I tightened up the screws that held in the sensor.
The wiring was bad. Very bad. About an inch above the connector it was very brittle and about an 1/8" to a 1/4" inch of insulation was gone. I gently pulled it to the top of the engine, cut out the bad bits, found some suitable replacement wire, slipped heat shrink over everything, soldered a bit, and applied heat to the wrap and it shrunk. And Bob's your Uncle.
