D1 Intermittent Cut Out Problem remedied
Old May 25, 2021 | 06:09 PM
nzajg's Avatar
Default D1 Intermittent Cut Out Problem remedied
For those who may be interested. I had previously posted an issue with my 96 D1 Facelift, the fault being an intermittent and repetitive engine cut-out when at temperature. The source of the fault was identified by member WaltNY, who convinced me that the Vehicle Speed Sensor was the most probable cause. I renewed the VSS and I rewired this circuit through the Speedometer. The fault remained, but on putting a switch inline, when ‘off’ the fault remedied itself, which back ‘on’ the fault reappeared. (Further to this I replaced almost all other engine sensors including the MAF.) I was at a dead-end, but WaltNY convinced me to restudy the schematics and rethink the issue. Finally, on rechecking the wiring the connector (C152) on the Coolant Temperature Sensor (X126) appeared brittle and the loosened back spring had dislocated the connection. A new connector was soldered into the circuit. Now with running the truck for two weeks, the fault seems to have cleared.
Interesting is that from the schematics, I remain at a loss to identify the circuitry link between the VSS/Speedometer circuit and the Temperature sensor. Unless it is ECU software?
One thing is absolute with modern Land Rover faults: ‘Perseverance Got the Snail to the Ark’
Many thanks for your help.
Old May 25, 2021 | 09:58 PM
Best4x4's Avatar
I had that when a CPS was on it's way out.
bjordan
Sep 25, 2019 11:06 AM
krammark
Sep 15, 2016 10:15 PM
Lupin 3rd
Nov 27, 2012 12:34 PM
hh65flyer
Nov 30, 2011 05:40 PM
sharp
Feb 5, 2009 09:11 PM
