Help with P1590 codes
Old Nov 27, 2012 | 12:34 PM
Lupin 3rd's Avatar
Question Help with P1590 codes
Here' the readouts from the diagnostics reader (these should be ABS - related):
Front left sensor output too low. Fault logged
Front left sensor output intermittent. Fault logged
Front left sensor electrical failure. Fault logged
Front right sensor output too low. Fault logged
Front right sensor output intermittent. Fault logged
(While these should be SLS related, I've since installed coils.)
Rear left corner valve duty exceeded. Fault logged
Rear left corner valve power amplifier open circuit. Fault logged
Rear right corner valve power amplifier open circuit. Fault logged
Exhaust valve power amplifier open circuit. Fault logged
Compressor relay power amplifier open circuit. Fault logged
Plausibility fault raising rear left. Fault logged.
Unknown fault code 0000
Can I fix the ABS faults with the two front sensors by just replacing them or is there something else that I need to address first? Is there a way for me to check that the ABS sensors work (measure Ohms, what voltage they should see)?
Thanks in advance!
HopeItsNotAMoneyPit
Feb 18, 2015 04:18 PM
tantra12
May 8, 2013 03:28 PM
Draayer
Aug 29, 2012 09:10 PM
droland@teksinc.com
Jun 7, 2011 09:23 AM
oraquest
Jul 25, 2008 09:13 PM
