D1 Oxygen Sensor Woes
Old Jun 29, 2024 | 04:35 PM
boy_the_wonder's Avatar
Default D1 Oxygen Sensor Woes
Hey folks,
I’ve got a ‘96 D1 that is throwing upstream O2 sensor codes (P0130 & P0150). I’m a little confused about which O2 sensors I’ll need, as I’m not sure if my car has AEL or not. My VIN is SALJN1247TA174490 and my EVAP family is TLR1060AYPOC. I’d really appreciate if you guys could point me in the right direction. Thanks so much!
Old Jun 29, 2024 | 10:42 PM
JohnZo's Avatar
Is your charcoal canister round or square?
Round is non-AEL and square is AEL. My '96 is non-AEL, not sure when the change was made.
Old Jun 30, 2024 | 09:29 AM
Looks like I’m non-AEL then too, I’ve got the round canister. Thanks for that! Looks like I’m pretty much stuck with Rovers North or AB for the sensors, huh? Or can I find them any cheaper elsewhere?
Old Jun 30, 2024 | 10:14 AM
JohnZo's Avatar
My usual go to vendors are AutohausAZ or Rock Auto for low cost parts, but both are more expensive than AB for O2s. A nice detail from AB is the VIN (VA350101) that changed to AEL.
Old Jun 30, 2024 | 10:51 AM
jvarnadoe's Avatar
I purchased my non-AEL O2's from Lucky8 last year. It was the most economical place I could find for them at the time.
https://lucky8llc.com/products/xygen...jection-set-x2
Old Jun 30, 2024 | 04:50 PM
Thanks very much for the insight, folks! Going to place an order tomorrow and tackle the job when the parts arrive.
Old Jul 1, 2024 | 01:25 PM
whiskeynipple0088's Avatar
double check the connector that goes over the bell housing (from left side or passenger side US) - My 98 had the connector clip broken - kept working loose then throwing a code till I zip tied it - I discovered this when I was going to replace the O2 sensor - its still in the box on a shelf 10yrs on....
Old Jul 2, 2024 | 12:11 AM
Seems my connectors are pretty solidly fixed to the bell housing, so probably just time for some new sensors. Thanks for the tip though, definitely worth checking.
Old Jul 2, 2024 | 12:27 PM
JohnZo's Avatar
Another tip: Rearrange the connectors locations so they are easier to reach for next time. Ensure wire route does not contact exhaust manifolds.
Old Jul 2, 2024 | 02:54 PM
jvarnadoe's Avatar
How can they be rearranged? The connector lead terminates above the bell housing and the O2 wire is just long enough to reach it. There didn't seem to be enough wiring to move anything around. From what I remember the driver side was pretty easy, but the passenger side was a pain. I had to reach above the bell housing, finagle the connector around and snap it together with one hand. I was sooo happy when I felt and heard that click!
I looked for extensions when I replaced my O2's but couldn't find any.
