D1 steering leak
Old Jul 18, 2012 | 10:46 PM
EricTyrrell's Avatar
no no no calm down it's not ruined. Just fix whatever the leak is and flush it with fresh ATF. No need to be an alarmist.
Previous owner put coolant and metal shavings in my PS and it survived. My new pump is from a Chevy S10, but is nearly identical, and actually takes PS fluid.
Old Jul 18, 2012 | 10:53 PM
olywa's Avatar
I hope so. It it is leaking that it's empty. It might be okay.
Old Jul 18, 2012 | 10:56 PM
olywa's Avatar
Dexron III ? How much?
Old Jul 18, 2012 | 11:04 PM
olywa's Avatar
Is there a tutorial in how to flush?
Old Jul 18, 2012 | 11:10 PM
olywa's Avatar
The leak.
Old Jul 19, 2012 | 12:09 AM
There are two notches on the power steering reservoir cap. Keep the level between the two. The easiest way to bleed/flush the system is to loosen the zerk looking fitting on top of the power steering box just a little, not the big nut. While ATF bleeds out, keep filling up the reservoir. Don't let it go low! Bleed it till the fluid looks fresh. The ATF will go everywhere so make sure to put a pan underneath and wipe up the rest.
Old Jul 19, 2012 | 12:25 AM
olywa's Avatar
Okay. I need to order the hoses and replace them all. I hope it just the hose.
Old Jul 19, 2012 | 01:14 AM
If you're sure the hoses are the problem, then yes that should be a big improvement. Make sure to use new hose clamps as well. I ordered my hoses from British Pacific. Cheap and good quality.
Old Jul 19, 2012 | 10:51 AM
wheelgarage's Avatar
Ditto.
...need to remove fan assembly to get to the pump...the rest is straight forward....
Old Jul 19, 2012 | 12:12 PM
I managed to rebuild the entire PS system without removing the fan. It was a little tight but not bad really.
