D1 Suspension questions
Old Nov 18, 2017 | 10:02 PM
RedRovin''s Avatar
Default D1 Suspension questions
Just a few questions I couldn't find an answer to:
First, any ideas why my passenger rear end sags 3/4 inch lower than the rest of the truck? I tried swapping the springs from each side but its still present. It also did this with the stock springs before the TF install. Axle height is even, its the height between axle and frame that's off. Would a twisted frame cause it?
Second, any additional suggestions for solving this gap between spring and mount? It's only on the rearward surface, and I believe it's causing my "pop" noise when accelerating and breaking. I know the gap is tiny, but I speculate the spring is doing more shifting than normal. (Btw, this "pop" didn't start till after an off road weekend)
My plan for the spring is D2 isolators. Any additional suggestions are appreciated and welcomed!
I'll add my third question tomorrow when I take a picture of it because its hard to explain.
Old Dec 10, 2017 | 10:10 AM
advntrjnky's Avatar
I would bring it by a good frame shop and have them check if it's tweaked a bit, before you try fixing anything.
advntrjnky
Old Dec 10, 2017 | 02:54 PM
The popping after off roading can be worn out bushings as well. I finished off more than a few hitting the trail in the last few months
Old Dec 10, 2017 | 04:01 PM
ihscouts's Avatar
Um, anybody mentioned body mount yet? I would think if your swapping springs like a madman and it's stay'n the same then you'd have a body mount that's gone south (sorry South). Check the "C" pillar mounts, they like to crumble and check the two directly under the cargo door floor brace....great spot to punch through.
Frig'n old thread already.....
Old Dec 10, 2017 | 05:56 PM
lol didn't catch that
Old Dec 11, 2017 | 06:27 PM
RedRovin''s Avatar
advntrjnky
I'll try this as last resort. Hopefully I can find one nearby.
I'm all for new parts on this thing so I'll give it a try.
Turns out this was my popping problem. That and loose bolts. Replaced front axle mount bushings and tightened all the bolts on rear wishbone. No more popping.
Old Dec 12, 2017 | 07:59 PM
ROB99DISCOSD's Avatar
Sweet! Good job. Now ain’t that satisfying???
TRIARII
Jun 30, 2022 09:48 AM
ljdiscovery
Feb 13, 2016 11:21 PM
Aaron Sandland
Feb 12, 2015 09:35 AM
fastrx7man
Jan 28, 2012 12:49 PM
amvauto
Aug 16, 2007 07:50 AM
