damn lower radiator hose
So, I'm on my way to eastern Washington with the whole family in the disco and pulling a travel trailer when all of a sudden I see a cloud of white smoke behind me. My first thought is head gasket, so I pull over and POP the hood and there's a steady stream of coolant pouring out of a small gash in the lower radiator hose, right where the smaller hose from the tank joins the bigger hose.
I'm about 5 miles north of north bend wa sitting on the side of I90 assessing my options. Thank god for smartphones. There's an oreillys back in north bend but it doesn't open for another two hours so I put some Goop over and will let it sit until they open.
If they don't have a lower hose, should I try one of those hose repair kits, anybody use one? The hole is in an awkward spot where the two hoses meet.
Anybody in the area that has a spare hose wanna meet me somewhere nearby?
Thanks all
Thanks all
If they don't have he right one you could Mc Guyver a lower hose on eliminate/bypass the heater and reservoir and coolant return hoses, remove radiator fill plug, disconnect the upper hose, fill till coolant comes out, reasemble and pray.
If it makes you feel any better
I had to do a roadside a/c compressor clutch repair on my Volvo using plastic bread bag clips and some tools i bought from a small Sears appliance center. I did this each day on my 9 day road trip.
Best of luck and remember It's always an adventure (with a few detours) with a Land Rover
So while I'm under the truck, looking at the hose connections, I notice that the passenger side front tire is extremely worn on the inside. It didn't look like this yesterday. I've put about 500 miles on this thing before this trip and haven't noticed any abnormal wear until now.
Could this be caused by towing the trailer or does it just need an alignment?
The rest of the tires look fine.
