Death Shake
Old Jul 3, 2014 | 12:41 PM
georgep's Avatar
Question Death Shake
1998 has the SHAKES and then got sick and puked up the power steering fluid on the road.
Ordered:
Ps Pump
Ps hoses
Rebuild kits for wheel bearings (assume that is the shakes)
Anything else in parts I might need?
Waiting to put it up on the lift till I have the parts in house.
Old Jul 3, 2014 | 12:47 PM
MM3846's Avatar
trackbar/panhard rod. 90% of the time death wobble is a bad/loose trackbar or bushings in any solid axle truck.
Old Jul 3, 2014 | 12:56 PM
georgep's Avatar
Great that is what I did NOT order.
Old Jul 4, 2014 | 10:19 AM
MM3846's Avatar
its easy to check. look under the truck at the bar while someone turns the wheel. youll know the bushings are bad immediately. DONT buy non-oem ones... my britpart ones are bad after a month and i have to do them again.
Old Jul 4, 2014 | 10:39 AM
georgep's Avatar
I get 90% of my stuff from Atlantic British, So far so good. Might try and find polly bushings
Old Jul 4, 2014 | 02:36 PM
wrongway1's Avatar
Got an orange poly bush kit from lucky8llc for my 98. It took care of the shakes till my steering box capped out on me a few weeks ago. But the kit really changed the ride for the e better.
Old Jul 4, 2014 | 04:19 PM
MonteroMan's Avatar
Default Imbalance
"Rebuild kits for wheel bearings (assume that is the shakes)"
Mmm.. I do not see how this will effectively cause a wobble?
Old Jul 4, 2014 | 04:41 PM
HammerFit's Avatar
How so? What will happen to make you think it is def them?
Old Jul 4, 2014 | 09:46 PM
TOM R's Avatar
Also che k tie rod ends, cheap Moog on amazon, check swivel pre load,like having bad ball joints if loose
Old Jul 5, 2014 | 01:03 AM
CUpgt's Avatar
If the bushings are bad you will see play immediately. Mine was so bad you could rock the panhard by hand. It was an All Makes that lasted all of 6k miles. OEM is best in this application.
