Deceleration roar
Deceleration roar
Got a weird thing going. When I decel from 70 to 50 mph I get a roar from the front. It does not shimmy the truck nor the steering wheel and it does not vibrate the transfer case. It seems like coming from the front axle cause it does it with the driveshaft removed as well. It's like a grinding/roar sound-feeling. Could my abs activating. Ive disabled the abs but it did it before I disabled it.
It started when I put the hd tf springs in but since I have put the stock springs back in it. No luck. Any ideas
Ok my mechanic said he retorqued my pinion shafts while he changed out my u joints but the deceleration roar is still there....it only roars when you go 50+mph and you go part throttle, if you just let off it does it for a split second..and it decals fine without any vibs or grinding roar noise.
It does not make any noise when turning...so its not the CVs...could it be bad wheel bearings?
Also just FYI this happens even if the front shaft is removed so it is not the Transfer case...its coming from the front axle...more so by the wheels....no shaky steering or anything..just a grinding/roaring noise from deceleration 55+
