Deglazing/honing
Old May 4, 2016 | 08:25 PM
spurcap's Avatar
I think I am going to go ahead and order my parts with the plan of following the old manual with a cross-hatch. As a related question, anything you guys think I am missing given the engine is fully apart? Or anything I probably don't need to save some money? Priced out at AB but would be interested in other sources if anyone has recommendations. Total with shipping comes to $1,682.
- Main bearings, rod bearings (STD)
- Oil pump w/ gasket
- Piston rings
- Cam + lifters + new cam bearings
- Timing chain set w/ gaskets
- Front and rear main seals
- ARB main bearing stud kit
- Rear cam engine plug
- Block freeze plugss
- Main bearing side bolt seals
- Head gasket kit w/ bolts from AB (includes all top end gaskets I think). Likely have some gasket duplication in my list but playing it safe than sorry unless someone confirms.
- New thermostat and gasket
Old May 5, 2016 | 04:08 AM
ihscouts's Avatar
AB has the absolute highest prices of any LR vendor. Everything on your list is available from Rovahfarm.com and also through Lucky8. ARP studs are absolutely not necessary unless your adding induction and that's as available and useful as a three eyed chimp.
Old May 5, 2016 | 05:26 AM
RedRovin''s Avatar
Yes
Have read this is useless to replace unless you know for sure it's broken
- Piston rings
Yes
Same as oil pump (except bearings) if you still want to replace, aftermarket Crower Cams are cheaper than stock IIRC.
Yes, I did
Yes
Not needed
Yes
Probably not needed, but cheap so I did mine as well
Comes with head gasket kit
Obviously yes. Lol
Yes, but gasket comes with kit as well.
Hope that helps. My advice, pay good money for a good machinist. Have the heads and block cleaned, inspected, and squared. Triple check bore measurements. Balance the flywheel if needed. And research torque specs. There is a bit of discussion on correct torque spec and whether the manual is accurate and tight enough...
Old May 5, 2016 | 08:32 AM
ihscouts's Avatar
These engines are internally balanced and flywheel is damped. Balancing the flywheel would be only balancing the flywheel...... Just noting eh.
Old May 5, 2016 | 09:03 AM
TOM R's Avatar
I bought everything on amazon and I think a lot shipped from lucky 8
Old May 5, 2016 | 10:19 AM
RedRovin''s Avatar
I may have wrote flywheel but was thinking crankshaft. Haha my bad.
Also, I bought all of my stuff from rovahfarm except 1 or 2 things
Old May 5, 2016 | 10:37 AM
spurcap's Avatar
Thanks guys. That's exactly what I was looking for - recommendations of better or cheaper part sources. Have my block and crank with my machinist now. Will post prices from the other sources here for comparison
Old May 5, 2016 | 12:31 PM
WNYErikDiscoII's Avatar
Former Sponsor
- Piston rings
I can do all of this delivered for under $1000
Old May 5, 2016 | 12:36 PM
spurcap's Avatar
Do I need to replace connecting rod bolts? I knew you did for main bolts but the overhaul manual doesn't say to discard the rod bolts... But they show on RovahFarm as "Do not reuse"
Also what is the difference between a "floppy" and a "stiff" chain in terms of application. They are both listed on Rovahfarm and both show as applicable to a D1.
Where do ERR3330 and ERR3331 go? And how many do I need of each?
Front and rear oil seal recommendation: All-makes vs Carteco?
Can't seem to find main bolts on RovahFarm... Does anyone know a P/N? Checked to AB for a P/N but they only sell ARB as far as I can tell.
Old May 5, 2016 | 12:59 PM
spurcap's Avatar
I am interested. Will order once I hear back from machine shop to confirm all is good with block.
