DI Dist. vacuum advance replacement
Old Feb 12, 2014 | 06:20 AM
green-lantern's Avatar
LAND ROVER DISTRIBUTOR IGNITION MODULE DISCOVERY RANGE CLASSIC DEFENDER STC1184 LUCAS | Miami British
Well this says it's the same but it doesn't look like the same setup as the distributor in the original post. I guess the one in the OP is a 2 pin.
Old Jan 23, 2024 | 11:33 PM
JohnZo's Avatar
Here's an update. My side by side comparison: 3-pin version (more expensive) is for the 94-95 Discovery. It has a stronger spring and slightly shorter arm than the 2-pin version (cheaper), so the advance curve will be different, and the initial timing position will be different.
bozman669
Feb 28, 2013 06:58 AM
Cosmic88
Aug 10, 2010 05:24 PM
cranky
Aug 6, 2010 07:59 AM
Lnghrn Disco
Jun 6, 2007 10:26 AM
redmond
Oct 3, 2005 04:45 PM
