Disco 1 Fixes and Upgrades
Old Nov 29, 2021 | 02:36 PM
beltman's Avatar
4th Gear
Default Disco 1 Fixes and Upgrades
Greetings all,
Still somewhat of a newb on going after my 1998 Disco 1 50th Anniversary edition, I'm interested in making appropriate, tested, and clean mods that are classy, yet practical.
  1. I have managed to break the front of the in-dash Coin Tray (the felt lined one.) It is just the front plastic facia that I've broken, the rest of the component can be removed and reinserted without issue. I've tried to find a replacement (Part #BTR6625LNF) but noone seems to have one and it is discontinued. It appears to use the same opening as the Clock Assembly. Does anyone have a cool idea for using that space that still looks classy and as close to original as possible? Or, does anyone have a replacement for that Part?
  2. Speaking of the Clock - I've replaced that digital clock several times, and can't figure out why it constantly goes bad. I have seen Analog Versions from time to time but I can't find any online. Anyone have any ideas where I can buy one?
  3. Time to replace my original Stereo Head unit, and want to put something with a Apple Car Play capability along with a slide out/slide up display so that I can impress my kids. I've seen a Pioneer version that is supposed to be the "best" replacement unit, but I'd like to hear from someone who really knows first hand if it works and what works best. Any thoughts?
  4. I'd like to put on a Brush Guard - do I need to buy new, or is this something that I can buy used, and if so, any thoughts on where and what is the best product for the dollar?
  5. My front Driver and Passenger seats have split their seams on the bottom cushion. I can't find any articles on having them repaired/the leather replaced. Does anyone have some guidance on this?
Thank you all in advance for your advice and patience with me!
I'll try to make it up to you all!
Old Nov 29, 2021 | 07:28 PM
ononomos's Avatar
Pretty much any of those items on the dashboard (ashtray, clock) can be found on ebay. I would also check Facebook Marketplace for people parting out their Discos. I believe the analog clock is for the Range Rover Classic, and I’m not sure it functions with the Disco without modification.
I have a Kenwood head unit, works fine. More important than the head unit, if you want quality audio, would be to replace the original speakers (not that hard).
My driver’s seat was torn to shreds, so I ended up buying a leather seat cover from a Ford truck sewing it on myself. You could try putting a leather patch over the split… or a seat cover might be the simplest solution, unless you want to take it to a professional upholsterer.
Old Nov 29, 2021 | 09:59 PM
Best4x4's Avatar
RRC clock is out of a 95 and it's pretty hard to find them now for any less than a bar of gold. Easy to wire up though.
Old Nov 30, 2021 | 01:57 PM
beltman's Avatar
4th Gear
Ononomos,
You rock. Thank you so much for your complete response.
Argh.
I'll look at the Kenwood option. I like the Pioneer that is pushed in lots of places, but I'm a fan of hearing first hand from someone who has more than theory behind their recommendations.
And I'm guessing I'll go the Local Upholstery route as I do want the seats to look good. I wish I could find the Seat Cover Kit that is either the original or looks much like the original as I could do it myself....maybe it is time to quite being such a DIY'er and give some work to a pro.
Again, tons of thanks!
Old Nov 30, 2021 | 02:02 PM
WaltNYC's Avatar
some have posted favorably about lseat.com for new seat covers.
Old Nov 30, 2021 | 03:07 PM
disco96sd's Avatar
Find a breaker - that is your friend
Old Nov 30, 2021 | 08:19 PM
DiscoNewbe's Avatar
their service is annoying, they don’t respond. My replacement from Lseat is in good condition, but a pain in the butt to install, very tight fit.
Old Dec 1, 2021 | 11:23 AM
WaltNYC's Avatar
DiscoNewbe, that is good to hear (sorta). I take it you are happy with the finished product, difficult as it may have been to install. Could you please post a picture or two? I am going to need something soon.
Old Dec 1, 2021 | 01:57 PM
DiscoNewbe's Avatar
it does look good, I feel like the only other alternative is paying exponentially more for replacements.
below are some pictures I just happen to have on hand. It does seem like the material stretched out a bit with use getting rid of some of the wrinkles you see in the picture. I would say you have to be careful installing, I did feel once or twice a stitch give out from being too forceful.
Old Dec 1, 2021 | 04:28 PM
Best4x4's Avatar
Friend grabbed me some parts off a 95 RRC LWB today!! Got the unicorn analog clock for 6.00 in mint condition, the RF passenger kick panel (holds the owners manual unlike a D1), the 4.2L V8 14CUX ECU, and the 4.2L stamped upper plenum.
lschwarcz
Audio/Visual Electronics
Mar 17, 2021 11:23 AM
Afields
May 3, 2020 06:30 PM
JONW
Defender
Feb 5, 2017 10:06 PM
Jumannen
Sights N Sounds
Oct 21, 2014 07:47 AM
gschmitt
30
Mar 11, 2014 04:43 PM
