Disco 1, Fixing the Turn Signal Light Not Resetting
Old Jan 15, 2019 | 08:47 AM
98-Disco's Avatar
3rd Gear
Default Disco 1, Fixing the Turn Signal Light Not Resetting
Hi, I am not sure if this is right section for this DIY repair guide, if not, please let me know. Thank you.
I got this 1998 Disco 1 MPI 2.0 a few weeks ago as a project (back up) car, I will try to share what I have done here.
I fixed the turn signal not resetting issue, apparently, it is a common issue for a twenty years old car hence there is a repair part available, the OEM part from the dealer is quite expensive as I was told.
Symptom, after finish making a turn, turn signal won't reset (turn off) even steering wheel has already return to center position.
Disconnect the battery Negative terminal before you begin, your neighbors will love you for doing that.
whowa004
144
Sep 3, 2024 11:02 PM
dmannrover
Jul 31, 2019 11:57 AM
loanrangie
May 28, 2015 08:13 AM
RoverLover21
Nov 21, 2009 02:41 PM
