Disco 1 maximum tire size
Old Jan 26, 2011 | 07:54 AM
eddie58's Avatar
4th Gear
Default Disco 1 maximum tire size
Hi guys.
I used to run 33 BF Muds on my Wrangler with Dana 44 fullsize front axle and Dana 60 back axle. The axles could hod up to the tires including Detroit Locker in the back and ARB in the front, with 1:4.56 ratio in the axles.
I recently bought a lifted 1996 Disco 1 with 245 75 16 tires. What I would like to know is what would be the maximum tire size that the axles could support without breakage and without having to go into more modification such as heavy duty bearings etc. I have no problem with fender trimming and of course changing the gear ratio in the axles. Any opinions? Thanks!
Old Jan 26, 2011 | 08:49 AM
thehun's Avatar
id say your about there....32" would be max i would want to go on stock axles
Old Jan 26, 2011 | 08:53 AM
Spencerfitch's Avatar
35 if you do light wheeling and just want a big tire. 33.5 if you do serious wheeling. 32 if you wheel the FK out of it. Really depends on terrain
Old Jan 26, 2011 | 10:29 AM
Long Haul's Avatar
These axles are as strong as a dana 44 just not the spider gears. I run 33"s with ARB f&r and beat the **** out of it. The best part about the axles is that they are full floating so no real issues with the axles breaking because of the larger tires its mostly just the gears an carrier are the weakest link.
Old Jan 26, 2011 | 10:27 PM
eddie58's Avatar
4th Gear
Default Thanks for the replies
I think I'll go for the 32's. Thank you all.
SilverDisco04
Aug 23, 2013 04:57 PM
codemunky
May 26, 2011 11:17 AM
GregHaugen
Dec 12, 2007 05:49 PM
rangeballs
Oct 8, 2007 05:39 PM
jcolumbia23
Oct 3, 2007 12:12 PM
