Disco 1 Overheats when in drive...
Old Mar 31, 2015 | 09:56 AM
  #91
USNAVYORDNANCE's Avatar
Bald 265/75 BFG AT's before, aggressive Nitto Trail Grapplers in 285/75. I figured that was about right in mpg drop. I'm also sitting a lot higher than before.. Doesn't really bother me much. I gladly sacrifice 3 mpg's for the gnarly stance, ground clearance and traction.
Old Mar 31, 2015 | 03:42 PM
  #92
Gimebakmybulits's Avatar
Did you use a correction factor for tire size or a measured distance? I've never done better than 10.5 (245/70/16's) and at some point need to figure out whats wrong.
Old Apr 1, 2015 | 10:32 AM
  #93
Distance. Miles per tank x3 (measured 3x and average of results). Remember, I'm running off a fresh rebuild/stroker. I'm sure as she tires out, she'll drop in mpg's but for now I'm happy with my numbers
Old Apr 2, 2015 | 08:12 AM
  #94
TOM R's Avatar
I reset my ecu adaptive values and I jumped from 9.5 to 13.5 MPG with all the crap on mine
Old Apr 2, 2015 | 11:53 AM
  #95
How'd you do that Tom? Might try it and see if jumps back up.
Old Apr 2, 2015 | 08:05 PM
  #96
TOM R's Avatar
Need a rover scanner with reset ability
Old Apr 3, 2015 | 10:00 AM
  #97
Roger that.
Old Apr 3, 2015 | 02:40 PM
  #98
TOM R's Avatar
Where did you source all your gaskets and bearings?
Old Apr 3, 2015 | 08:45 PM
  #99
eBay had em
Old May 18, 2015 | 07:24 PM
  #100
TOM R's Avatar
In here page 8 said you used 4.6 crank and rods and IInjectors? Yes?
