Disco ARB bumper compatibility
Old Feb 28, 2019 | 11:41 AM
Caleb McKenzie's Avatar
4th Gear
Default Disco ARB bumper compatibility
Does anyone have any information regarding the installation of an ARB Deluxe bumper designed for the Disco 2 Being installed on my Disco 1? I came across a really good deal on one and I’m curious if it will fit in mine. The picture attached is the one I would be buying I’m not sure if it’s of any help
Old Feb 28, 2019 | 01:48 PM
stillruns's Avatar
Probably not, just a guess.
Old Mar 1, 2019 | 10:02 AM
logan_gibson's Avatar
It bolts up just fine, I just put one on my D1 from a D2.
Just unbolt it from the D2, pull the D1 bumper off, and slide it onto the D1.
An engine puller/cherry picker makes this easily doable by a single person.
You will have a slight gap in-front of the grill from where the D2 bumps out but the D1 does not.
I can grab a photo of mine install here around lunchtime.
Old Mar 2, 2019 | 10:00 AM
Best4x4's Avatar
I'm running a D1 ARB on my 99 D2, and when I had a 98 D1 LSE I ran a 99-02 ARB bumper without any issues. The main differences are the cut off around where the grills are. 03-04 grills are shorter so the bumper isn't cut out like the 94-99 D1 ARB or 99-02 D2 ARB's. Also when I mounted the D1 ARB onto the D2 I had to cut off two small sections due to the D2's different front cross member area at the frame. You will not have to do that with a D2 ARB going onto a D1.
Old Mar 18, 2019 | 11:57 AM
4th Gear
Hey guys thank you for the input! I decided to pick up the D2 bumper after going to a local junkyard and measured D2 vs D1 K frame mounts and determined it would at least bolt up and sure enough it did and it fits great!!!
Richard Gallant
Oct 8, 2019 05:20 PM
bergin90
Jan 20, 2016 01:44 AM
FantomRover
13
May 20, 2014 06:49 AM
robertf
Oct 24, 2013 11:01 PM
hunter
Aug 7, 2011 05:04 PM
