Disco1 LT230 Siezed
Old Dec 7, 2017 | 09:45 AM
Disco101's Avatar
5th Gear
Default Disco1 LT230 Siezed
Hey guys,
I have a 94 discovery 1 that got huge crack in the transfer box. The fluid leaked out and caused it to lock up while driving. Had to remove drive shafts and tow the truck home. Would just replacing the LT230 fix this or do you think something else could also be damaged?
Old Dec 7, 2017 | 09:53 AM
could just be the transfer case, you might have gotten lucky. Check the driveshafts to make sure they don't appear twisted. Check the diffs by getting the tires off the ground and spinning them listen for funny noises or crunchy/notchy movement
Old Dec 7, 2017 | 10:09 AM
Disco101's Avatar
5th Gear
Ok I will give that a shot. Thanks.
Old Dec 7, 2017 | 12:31 PM
DavC's Avatar
I believe you could be OK, the only other damage I could maybe forsee is mainshaft spline wear on the trans, but you would immediately notice it when changing the transfer box when you replace.
Good luck.
bn_bnntt
Aug 4, 2011 03:45 PM
fuctifano
Dec 22, 2010 08:55 AM
95RRlwb
Jun 11, 2009 09:28 AM
cold_surfer
Mar 21, 2007 01:38 AM
