Discover 94 electrical problem help!
Old Feb 26, 2011 | 11:37 PM
VHOA's Avatar
6th Gear
Default Discover 94 electrical problem help!
I have a 1994 discovery with an electrical problem, I fixed the alternator and replaced the battery and it runs fine during the day, but at night, the lights in the car go down until the car runs out of power until I jump start it again. The mechanics can't find the problem...HELP
Old Feb 27, 2011 | 02:49 AM
nahtanoj's Avatar
check the routing of the belt.
i bought my 96 rover being told the alternator was bad. i replaced it and it didn't fix the problem.
i checked the belt routing and it was wrong. fixed the belt routing and what do you know, it worked.
sounds easy, but it is easy to overlook. and the belt goes on wrong, easier than it goes on right.
Old Feb 27, 2011 | 09:52 AM
VHOA's Avatar
6th Gear
like this?
thanks for the reply.
Old Feb 27, 2011 | 12:13 PM
nahtanoj's Avatar
yep, that's the routing with an a/c.
Old Feb 27, 2011 | 12:52 PM
Danny Lee 97 Disco's Avatar
That will definitely give you a problem.
Old Feb 27, 2011 | 01:39 PM
VHOA's Avatar
6th Gear
Old Feb 27, 2011 | 03:37 PM
Cosmic88's Avatar
Default ?????????????? =
What Danny means is IF your belt is routed incorrectly ..."That will definitely give you a problem"
That Diagram (if you have A/C...and who doesn't?) is the correct route. Otherwise your Alt will not charge the batt.
racerxnet
Feb 17, 2013 05:39 PM
jbremser
Dec 26, 2008 03:07 PM
disco ii hse
Aug 20, 2007 02:47 PM
skins
Sep 11, 2006 06:15 PM
My98disco
Aug 4, 2005 01:21 AM
