Discovery 1 inlet plenum chamber
Old Jan 7, 2022 | 05:54 AM
obicat's Avatar
Default Discovery 1 inlet plenum chamber
I've got a Mk1 Discovery 1997 V8 petrol automatic range rover. I've had a few issues with air leaks most of which are now resolved, but we've hit a brick wall. The plenum/intake chamber needs replacing, its leaking in several places. The garage cant source one. Any alternatives wont work as apparently the fitting on the end differs from other vehicles and therefore they cant find a part to fit. I've tried the usual places. Is there anywhere else I can try? I there a work around to use a different part?
Old Jan 7, 2022 | 07:31 AM
disco96sd's Avatar
Where are you located ? if you are in the UK there are millions of Disco's in breaker yards that would have that part - same with USA
Old Jan 7, 2022 | 10:35 AM
JohnZo's Avatar
If you mean the aluminum is cracked or developed a hole somehow, epoxy could work to seal the leak. My discos have an upper intake plenum, a lower intake plenum, and an intake manifold. Which one do you need?
austinlandroverbill
Dec 13, 2021 07:47 PM
andino
May 18, 2021 12:27 PM
Kyleocean
Dec 2, 2020 09:18 AM
hellokitty
Jan 13, 2020 06:29 PM
Pearramp
Aug 27, 2019 06:58 PM
