Discovery is a bouncy, tippy, rocking ride?
Old Aug 20, 2013 | 02:27 PM
archaeology_student's Avatar
Question Discovery is a bouncy, tippy, rocking ride?
Hi,
Just wondering if someone has any ideas. I notice that my ride has gotten bouncier over the years, and the best way to describe it is as though you are on a boat that is rocking back and forth on the ocean.
I have BFG T/A KO (10 ply tires) 245/75R16, all four filled to 40 psi. New Medium duty Old Man Emu Springs and Shocks (within the last 1-2 years) which gave me a nice 2" lift and were installed professionally.
Even prior to the lift I noticed the vehicle was feeling that tippy feeling especially on the highways at 80-90 Kph (50-55 Mph).
Any ideas? Could it be the toughness of the tires, or is there something I am missing?
Old Aug 20, 2013 | 02:53 PM
CUpgt's Avatar
If you bounce on one corner does it stay bouncing? If so its your shocks. If its swaying at speed check panhard, radius arm, trailing arm, and A-arm bushings.
Old Aug 20, 2013 | 03:04 PM
robertmirwin's Avatar
Agree with CUpgt. Could be a few really bad bushings or between all of them with just a little wear can translate to a bunch of wobble and sway.
good luck
Old Aug 20, 2013 | 03:35 PM
fishEH's Avatar
Buy the Orange Polybush kit and a press and replace them all.
Old Aug 20, 2013 | 03:51 PM
It is the latter, the swaying at higher speeds.
I will keep this in mind, and probable require new bushings as I don't think they have ever been changed.
Funny, my ex gf's '95 disco had a new suspension installed, and it handled almost like a car. Same tires as me, but stock size.
My mother's '99 Disco I also handles like a car and doesn't sway at highway speeds....
Thank you all for the help and input
Old Aug 21, 2013 | 05:03 PM
Just a couple of follow up questions.
I see a "SuperPro Poly Bush Kit"... does anyone have experience with these?
I see the orange polybush kit...
I also see that there is a red kit as well... and have read some other forums saying to go with OEM instead.
What are experiences, opinions, and overall consensus?
Thank you
Old Aug 22, 2013 | 08:01 AM
TOM R's Avatar
Mine is doing same, I know bushings are in my future, when I looked into this before everyone I read said buy the orange set
Old Aug 22, 2013 | 08:06 AM
drowssap's Avatar
watch what poly bushing you install, I replace all the bushing one of my jeepster with poly and the ride was terrible after, poly bushing also require special grease. jmo
Old Aug 22, 2013 | 09:10 AM
TOM R's Avatar
I have done jeeps, and ford trucks with radius arms, Chevy trucks, and my 01 dodge ram 1 ton 4 x4
So the swap is no biggie but I have only ever used energy brand, they do not seem to sell for rovers though
Old Aug 22, 2013 | 09:47 AM
EricTyrrell's Avatar
AFAIK all the poly bushings are more firm than stock, so I went with the blue(soft). Orange(medium) is between blue and red(firm). Also figured I'd preserve articulation by going with blue. Most guys go with orange though.
I hear the quality of genuine bushing used to be better, that's why guys go for the poly bushings now.
