Discovery I Fuel Leak Help
Old Mar 30, 2015 | 11:35 PM
pbrown2074's Avatar
Default Discovery I Fuel Leak Help
Looking for some help to tell me what boxes are in engine bay where I had a fuel leak in a 1998 Disco I. Passenger side in front of the windshield washer bottle. Leak is coming from the smaller box next to the washer bottle that has electric connection. Has a line running to the larger box in front of it that seem to have fuel lines to it. Pictures attached.
Thanks,
Paul
Attached Thumbnails Discovery I Fuel Leak Help-disco-i-fuel-leak.jpg   Discovery I Fuel Leak Help-disco-i-fuel-leak-2.jpg
Old Mar 31, 2015 | 05:07 PM
pbrown2074's Avatar
No one can tell me what roll these two little boxes play in the fuel system? Filter, pump? I am new to Disco I's.
Thanks,
Paul
Old Mar 31, 2015 | 05:27 PM
OverRover's Avatar
That's the Charcoal EVAP Canister for a Disco with AEL. How To Identify The Evaporative Emissions Family Of Your Discovery 1
Read on... https://landroverforums.com/forum/di...-called-44150/
Old Mar 31, 2015 | 06:06 PM
pbrown2074's Avatar
Should you be getting any fuel out of the valve after a fresh fill up?
Old Mar 31, 2015 | 08:11 PM
ihscouts's Avatar
Uh no. Seems your baby needs to be burped. Apparently your sucking fuel into the evap system. What type of fuel cap do you have installed, I'll take part numbers if you have em.
Old Mar 31, 2015 | 08:42 PM
pbrown2074's Avatar
I started the guy this evening and it did not put any more gas out the EVAP canister vent solenoid (ECVS). My son has the truck right now but will check gas cap after I get it back.
Old Mar 31, 2015 | 08:48 PM
pbrown2074's Avatar
1. EVAP canister
2. EVAP canister vent solenoid (ECVS)
3. EVAP canister purge valve
Old Apr 7, 2015 | 08:54 AM
pbrown2074's Avatar
Cap number is ESR2872. I bought another one of the same number and will see if that makes a difference.
Thanks,
Paul
JumPeR04
Apr 7, 2011 09:52 PM
chirmoney
Mar 1, 2010 12:03 PM
lipadj46
Jul 8, 2009 07:41 PM
40ranger
Apr 7, 2008 12:20 AM
rgrizzard
Mar 6, 2008 10:16 AM
