Discovery rear door stop?
Old Sep 23, 2010 | 03:46 AM
NZDiscovery's Avatar
3rd Gear
Question Discovery rear door stop?
Hi guys, I have a 1996 Discovery and when I open the rear (boot) door it swings all the way around until it bounches off the corner of the bumper.
Is there supposed to be a rear door stop that stops it going back past certain angle as it is making dent in the rear door!!
Old Sep 23, 2010 | 06:03 AM
Long Haul's Avatar
There should be a stop on the bottom on the hinge side of the door youll have to get down on your knee and look up underneith the door. Itll be a flat piece of metal atatches to the truck with a rivet and on the door I honestly forget...If you do a search on lubricating door hinges I know spike did a write up a while back that may have some pics
Old Sep 25, 2010 | 09:23 PM
3rd Gear
Thanks for the reply Long Haul. Found that the strap had become detached and was flat up under the rear door. I have lubricated the guide rail and hinges and reattached the strap to the little **** on the rear sill - everything good now - simple fix!! Thanks again.
CapeRover
May 3, 2013 04:35 PM
haleyrover
Jan 21, 2013 11:38 AM
psykokid
Jun 6, 2012 07:06 PM
thehun
Nov 19, 2010 10:22 AM
