Does the Discovery shift knob come off?
Old Sep 25, 2014 | 03:21 PM
unpolire's Avatar
4wd High
Default Does the Discovery shift **** come off?
I have removed all retainers but it appears to be molded to the shift arm of the transmission selector. How does one replace the worn-out "P, R, N, D, 2, 1" plastic slide material? I have a 1996 & 1997 and they are both in need of replacement.
Old Sep 25, 2014 | 05:03 PM
MM3846's Avatar
There is a small Allen head set screw holding the **** on
Old Sep 26, 2014 | 10:09 AM
unpolire's Avatar
4wd High
Default Where is the set screw?
This is great news, but I see no trace of an allen head set screw anywhere. I have checked the entire rubber surface of the ****, looked under the cover at the shaft and no hint of a way to remove it! I have the **** and the shaft down to the pivot point. It would seem a simple task not requiring more disassembly to remove the plastic housing. I need to remove the malfunctioning interlock mechanism (locks in Park position)so I can take it for its smog test, run in the Park position! I can drive it but have to manually disengage the solenoid plunger if I go into Park position. Almost there with one more hint!
Old Sep 26, 2014 | 10:22 AM
fishEH's Avatar
First, are you sure your brake light switch isn't bad? A faulty brake light switch won't disengage the interlock solenoid and you'll be stuck in Park.
Second, from memory removing the shifter **** is pretty straightforward. Pop the cover off with a small flat tip screwdriver. Then there's a C-clip I think. Then a nut you need to unscrew. After that the **** just pulls up and off.
Old Sep 26, 2014 | 10:31 AM
MM3846's Avatar
Originally Posted by fishEH
Second, from memory removing the shifter **** is pretty straightforward. Pop the cover off with a small flat tip screwdriver. Then there's a C-clip I think. The a nut you need to unscrew. After that the **** just pulls up and off.
ya this is right. maybe there is no set screw, i don't remember.
Old Sep 26, 2014 | 01:49 PM
Buddy Lee's Avatar
I've never seen a set screw on my 97 or 96's
Edit: I have had them stuck on before though where you just have to give them a good tug or tap with something to get them loose.
Old Sep 27, 2014 | 02:07 PM
Paul Grant's Avatar
The nut is 19mm and will probably be on there finger tight.
Old Sep 27, 2014 | 02:18 PM
nuclearw's Avatar
On mine there is a plastic cap (the dotted part on top) that you can pop off.. then theres a slide clip underneath to remove the ****.
Old Oct 3, 2014 | 06:53 AM
kevinjay's Avatar
the disco 2 **** comes off by grasping it and giving a sharp pull upwards . You could try this
razorbak
Oct 5, 2020 02:41 PM
fri3daz3
Aug 18, 2008 09:24 PM
APSIS USA
Apr 30, 2008 10:52 AM
Chrisinhouston
Nov 16, 2007 09:59 AM
martinez
Engine & Internal
Jun 3, 2007 04:47 PM
