Door Chime - On All The Time
Good Evening -
Being a new owner of a 94 Disco V8i - and my first Euro-Vehicle - I realize I may be asking a totally newbish question - Being that it's a 94 the owners manual is no where to be found, and the online versions don't mention the door chime -
Everytime I open the driver door there is a door chime - It only chimes when the door is open - No keys in the Ignition, no headlights on - which is what I am used to hearing from my GM/Ford products - If the headlights are on, it warns me, if I leave the keys in the ignition, it warns me. Maybe I am just not used to being warned about the fact that I am leaving the vehicle. Or maybe she (it) is going to miss me and is telling me so, or maybe she is happy to see me and telling me so. Either way, I want to make sure the door open chime is supposed to be happening.
Is this normal?
In Peace and Agape,
Trav...
Is this normal?
In Peace and Agape,
Trav...
Man I hate electrical problems. lol
I am thinking your ignition switch thinks your keys are still in the ignition.
You can try lubing the ignition with silicone spray and then working it a few times with the key.
my 96 had the same sort of problem but it only chimed some of the time with the key out and the key would get stuck in some of the time. a couple of shots of pb blaster and both problems solved
Thank for the input guys!
I was thinking along the same line. The guy i got it from stated it was always like that. But he bought it 2 years ago and only drove a couple times.
again..
Thanks,
In peace and agape.
Trav.
again..
Thanks,
In peace and agape.
Trav.
hmmmm. I replaced my ignition/steering lock with a part from Will Tillery. Before, I had not chime. Now I have a chime (really a constant beep). Also have a dome light that blinks until I start the engine. So the iginition is the problem, I'm just not sure a lube will do the trick because before I put the replacement in, I lubed that thing up quite well.
If you get to the bottom of the problem, please do report back, I'd appreciate the help.
yes they do and actually there r 2 diffrent chimes. one for the lights left on when u open door it is a fast beep and one for when the key is in the ignition and the door is open it is a slow beep or chime how ever u want to say it
